Originally Posted by sohman
toca 3 starforce 3.7
If you are mounting an image no emulation will be required. The emualtions only are for backup cd's. When you mout an image DT will automatically emulate it.
can you explain what you mean by backup cds? thanksOriginally Posted by AnalCobraIf you are mounting an image no emulation will be required. The emualtions only are for backup cd's. When you mout an image DT will automatically emulate it.we used to eat food but millionaire scientists got together & wanted us to eat a bunch of chemicals
The RMPS emulation is needed if you burn the DPM onto a CD/DVD and want to get the game (normally Securom ans Starforce need the DPM) working, for mounting it's not required. The Safedisk, Securom and Laserlock emulation is only needed if you put an non 1:1 copy of a game into your drive. A non 1:1 copy is for example a game which was copied/backed up with nero or by copying the files onto your hdd and then burn them as a Data CD.
So the Safedisk, Securom and Laserlock emualtion is nearly "never" required. Only if you put in a non 1:1 copy of a game which use this protection. Additionally the emulations are very old, so they only works with old Safedisk, Securom and Lasrlock versions.
What you say makes complete sense, I appreciate you explaining that, your one smart dude, thanksOriginally Posted by AnalCobraThe RMPS emulation is needed if you burn the DPM onto a CD/DVD and want to get the game (normally Securom ans Starforce need the DPM) working, for mounting it's not required. The Safedisk, Securom and Laserlock emulation is only needed if you put an non 1:1 copy of a game into your drive. A non 1:1 copy is for example a game which was copied/backed up with nero or by copying the files onto your hdd and then burn them as a Data CD.
So the Safedisk, Securom and Laserlock emualtion is nearly "never" required. Only if you put in a non 1:1 copy of a game which use this protection. Additionally the emulations are very old, so they only works with old Safedisk, Securom and Lasrlock versions.we used to eat food but millionaire scientists got together & wanted us to eat a bunch of chemicals
Makes sense. I have one 250gig sata 2 h.d running in jbod from the nforce controller and the game works fine. Maybe raid is to blame
Contrary to my previous post i just have to disable the controller, the sfn step isn't neccesary as it was with X3.
Its Definately a RAID issue!!!
Hi,
I'd just like to add that i have an Nforce sli with Nvidia and Silicon image SATA raid ports on my board (Optical drives 1 & 2 are still connected via 80way ATA ribbon cables though).
I had no end of trouble running this one, I was even going to try converting http://i12.my Optical Liteon DVD/RW and DVD Rom drives to SATA via two IDE to SATA dongles i have.
Then i thought, why not try just copying the image (MDS/MDF) to one of my three external USB2.0 Hard drives (connected via a USB extension and externally powered), and Bingo, It worked fine via DTools 4.03HE with the .Parralell ATA Port Disabled in Device Manager - No need to use SF blocking http://i12.photobucsoftware such as Starforce Nightmare....
I'm Chuffed as Chips now!
I'm pretty sure depending on your Cmos /Bios options , If you have setup your hard disks via RAID, you can just have a single SATA or spanned drives with no RAID function instead, although this'll mean a format of your system of course.
[IMG]photobucket.com/albums/a208/baron210/Picture003.jpg[/IMG]
[IMG]com/albums/a208/baketron210/Sucess.jpg[/IMG]
Raid Sata Nforce 3 Working.. If..
Sample just mount the img from a shared HD of ur network ..
Working fine.
1: Copy TOCA3 img on a HD of ur network. (Shared HD whatever)
2: Load the TOCA3 img with DeamonTool latest ver.
3: Start the game.
Wasnt working before because i used SATA RAID(Nforce3).
Working right away without any other tool then deamon.
Enjoy!
Work Around for RAID..
External USB HD or COPY the img on a network HD .. and mount it from there.
I wasnt able to play before because im using RAID(nforce3) dunno why. i just copied the img over a shared hd of another computer and mounted it. Working fine now.
Enjoy..
