I've created with my NEC ND4500a an image from this game, but if i start the game, it starts and then hangs on and go back to windows shell!! Something like "no disc found" are not there!!
War on Terror?? Don't work!!
This game is protected by SF 3.7.
What did you try to get it working?
Did you try unplugging your drives?
You need an Alcohol-image with DPM-Info.
Another thing you can try is to use a mini-image instead of using the full image and then try it without unplugged drives or with unplugged drives.
That method worked for Spellforce 2 also SF 3.7 protected.Last edited by AnalCobra; 19.04.2006, 14:38.
