I've created the image & has mounted the image. After I've selected the image, it juz open & view the files inside. The game doesn't run. Wat do I need 2 do to run the game?
Plz help!
@SCC: It would be very very nice, if you would describe the problem in explicit detail. :wink:
i was just waitin' for reading this comment.Originally Posted by BlazkowiczWell you have to run the exe of the game to play.
no way to hav phun wth sciendz
Okay. I'll explain in details.
1st of all, I used CloneCD to 'Copy the CD' in order to get the image file(CCD file). I've choosed to create the CUE file as well. I used a DVD writer to create an image on my hard disk, then. After it finished creating image, there's 4 files found on my hard disk -- CCD file, cue file, img file& sub file.
So, I mount the CCD file into my Virtual Drive, which is 'Device 0: [G:]'. After I've choosed to mount the image, it juz shows the file s inside my Virtual Drive (G
, which is the files inside the image. It only consist 3 files -- IMG file, 09 file & CNF file. I don't see any exe file. I've tried the cue file too. Same thing occured.
That's the case. Plz reply...
From which game do you want to create an image?
Does the original cd hast the same files on it like the image?
Use Alcohol 120% to create your images.
No specific game that I wanna copy. But for an example, I'm creating Final Fantasy VII's image. The image has the files exactly like the files in the CD. I've used Alcohol120% to create the image too. Same thing happened. It juz view the image file, not open the game. So, how?
