First of all I would like to say that I am not at all computer illerate, I have just never had to try and run a game by mounting it and then running some other program to hide the drive so that I can play. Anyways, many people have had the same problem that I have had with the godfather not being able to exit a vehicle after getting in and the mouse look being backwards. I have read many forums about how to get the game to work such as:
"when your not using the cracks you have to use
The Godfather [ENGLISH] No-DVD/Fixed Image #1 (ONLY)
mount that image (in DT) and then use a hiding tool like antiblaxx or SR7stop to hide the drive.
after you have done that the game should run"
I have mounted the image file but I am not sure how to use the other programs to hide the drive. If someone could explain in a little more detail on how to go about this I would appreciate it much. Thanks
