As far as i understood creating a mini image works through using the image assistant of alcohol for example and then immediatly breaking off the operation and keeping the small generated file.Now with oblivion not having a real copy protection on it, i thought creating a mini image would be even easier.
Here is what happened sofar, i installed alcohol and went on to create a mini image which promptly worked just fine. Today however when trying to run the game i got a message to insert the cd, so i unmounted and remounted the image with no result then i noticed that unlike yesterday the image was showing a size of 0 KB for all the conntent files in the image.... now i now yesterday that this wasn't the case. No problem i thought, i will just create another mini image, but the result is exactly the same, the generated file when mounted shows 0 KB for files in the image and that didn't change even when i created a new mini image that was 20 megs large, it still said 0 KB on all files.
The only difference between yesterday and today is that i now have rebooted the pc after that alcohol install, so could it be possible that alcohol installed some drivers that now after restart are working and messing things up? Or am i making some mistake? OR forgetting something??!
Any help would be appreciated!!
DarkG
DarkG
