Ok, I've set black and white 2 with compatibility to windows 2000, I've mounted the image on both Deamon tools and alcohol and tried to use stop 1.0 and safedisk4hide to hide the virtual drives, but it still detects the emulation software and and won't play, what am I doing wrong? how can I get Black and White 2 to work off the image?
Black and White 2 problems
Hi,
how did you create the image? (alcohol 120% image needed)
there is no need to set it in compatibility mode.
Mount the image using DT 4 and use sd4hide for antiblacklisting.
