I made a backup of a game with SecuRom New 4.84.84.0036 protection with Alcohol 120% and I enabled RMPS Emulation. I tested the backup cd out and it worked, I moved the backup cd to a different computer with no Alcohol 120% installed, but I install Daemon Tools 3.47, Windows Explorer displays the cd label correctly, and does not label it NO EMULATION. But the game executable still does not run. What I'm I doing wrong?
How to make Daemon Tools 3.47 work on a backup CD
So, did you enable the RMPS emulation (dt icon right click -> emulation)?
Is there any other disc duplication software installed, such as CloneCD etc? They may be blacklisted.
If it's not a pre Windows 2000 computer the game fails to run on, try upgrading to the current version of Daemon Tools (4.03)."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
