Hitman: BloodMoney (US-Version)
  • I have an another problem. in normal after cd amblem the game start,isn't it?but my game isn't start
    • does it start with the original?
      Carpe diem
      • I didin't try
        • You should try and tell here what happends
          Carpe diem
          • Bug With HITMAN Bloodmoney
            Hi,
            i have an mds/mdf image of Hitman, i mount it with D-Tools through Curerom and then run Securom Loader, The intro starts then the games ends and i get back to Windows...what can i do?
            • @asbatronic:
              Did you try to update Hitman, your graphic-card driver and soundcard driver. Maybe that helps.
              • Originally Posted by asbatronic
                Hi,
                Can you please tell that which graphic card is attached to your system?
                • ASR 1.2 works with my image i made and i updated hitman, perhaps it is a bad image
                  like the above user said
                  we used to eat food but millionaire scientists got together & wanted us to eat a bunch of chemicals
