PlanetSide...?
  • PlanetSide...?
    What method should I use to get an image of the PlanetSide game...?
    Thanks in advance for any help
    Cordially,
    Abel K.
    http://www.ngnicafe.com
    That depends on what protection the game is protected with. We don't have it in the Game Database, if you have a look here and check out the copy protection with one of the mentioned tools, we can tell you which profile to use in Alcohol...
    sG
