TigerWoods PGATour06 Question
  • TigerWoods PGATour06 Question
    Ive Made backups of Tiger Woods PGA Tour 06 then burned them to CDs, but how can I find out if there any good?
    I put in the first one and tried getting an image of it (to see if if its the same as the non burned image) but it gets tons of errors in Alcohol 120, is that normal for SafeDisk 4.50? Or are they no good?
    Read errors are normal for safedisc, don't worry.
      Are you sure when I just tried the CD3 it got zero errors, but CD1 got like 30 before it even got to 1MB, That normal?
        Yes I am sure, it seems only CD1 is copy protected.
          They only need to protect the 'Play' CD that has to be inserted to play the game
