I try to mount an image from gamecopyworld but all it does it start the game (black screen) then quits back to desktop. I am using Sd4hide but even if I do not use it it does the same thing. What is going on? I have been searching for a long time for the answer, and have not yet found a solution. Thanks for any and all help.
Battlefield 2 and Daemon
Did you installed the full 1.3 patch?
If this doesn't solve the problem, rename the vids into the following path:
XX:\Programme\EA GAMES\Battlefield 2\mods\bf2\Movies
XX:\Programme\EA GAMES\Battlefield 2\mods\xpack\movies
this happens to me too.
my image works fine with DT4...im to lazy to insert DvDs
the main problem is located here:
C:\Documents and Settings\xxx\My Documents\Battlefield 2
when my games crashes, and with 1.3 it does sometimes, i have to copy over a backup of those config files....
else it wont start.
