GUN how to back up
  • GUN how to back up
    Hey i just bought a copy of gun and when i got it home i found that Alcohol can not make back up copys of dvds with copyprotection.
    So now i am stuck how to make a back up image or backup cd
    Can you please tell me the program to use and/or what to do.
    Get the latest version of Alcohol 120% (www.alcohol-software.com) it can read images of DVD's. Then use Alcohol's image making wizard to create your image. Alcohol doesn't have profiles for the copy protections when you read an image of dvd's, so you've have to choose the best settings manually, but for Safedisk 4.6 you don't need to use any special settings (only choose the mds file format).
    You need to use a antiblacklisting tool like SD4Hide or CureROM.
      Alcohol CAN make backups of CDs / DVDs with copy-protections. Therefore it was developed.
      Use a program like Aray-Scanner 2.0.2.3 or ProtectionID to find out what protection a game uses. Then select the appropriate "Datatype" in Alcohol and start.
      GUN is protected with Safedisc 4.6 so you also need a program like Safedisc 4 Hider or something else.
      Here you find many informations.
      Also use the search function on top of the screen.
      Edit: Seems that AnalCobra can type faster than me
