I've just got a version of Devil May cry 3 Special Edition (For PC).
And it's protected with SecuROM 7.000.00000.00006 (I think it was a 6 at the end).
Anyway, my main problem is is that the game would only load ONCE, under very weird circumstances, and it was pretty much random.
This is what happens:
On normally launching the game it says it cannot find the original CD / DVD. and that it could not be authenticated.
On launching through an image on an emulator it says. ''emulator detected''.
On using SecuROM loader (The one with the asr.exe file) It says ''original CD / DVD could not be found / authenticated"
When I try using the ''reg-edit'' trick. It says ''Certain security modules could not be activated''.
In other words, when I try to bypass it, it doesn't bypass at all. Or it BLOCKS it completely, and apparently it won't work then as well :P
SO i'm wondering if anyone knows a way around this. (If I disable all other CD-Drives it still recognizes D-Tools as an emulator).
I have NO idea of what to do now.
And if you want to know how come it worked one time? I have NO idea, I was simply screwing around and I tried using the ASR.exe one more time. And *bam* It worked :O, like magic, totally unexplainable.
Can anyone please help?
