Relatively new to the Daemon tools world due to ignorance and not believing it could work (haha, can't work unless you try it). Anyways, do the long time users recommend setting all the emulations on all the time?
If you are able to make a good image (99% of the time you can);
you should only use rmps emuation. Safedisc and securom should be used if you have an old reader or one that can't read sub-channel very well.
