i know AoM uses safedisc 2.7 and im useing alc 120% (version 1.9.2) 2 make a copy, i can copy the first disc fine (i use the safedisc 2/3 option, u get those errors when you start coppying but then after that its fine) and when i go to copy the second disc near the end i get errors again for some reason????
when i go to install the game the first disc is fine but about halfway through installing the second disc it says im missing a file, so for some reason the second disc didnt copy right
A ray says there is signs of safedisc 2.7 on the second disc, but i have no idead why it dosent copy
HELP!!!!!!!
HELP!!!!!!!
