I need you because I have a big problem, I want to do a copy of my original sacred disc, i did it with Alcohol 120 % with protect CD VOB 5 options, then I uninstalled Alcohol, and have installed Daemon Tool latest version, I applied the patch 1.6(FRENCH) on sacred and this screen appears telling me : This CdRom/DvDrom cannot be validated due to installed copy protection emulation software.
I search throught this forum and check solution but I don't have found the same problem as me...
can U help me?:wink:
