Ok, i'm successfully backed up my copy of B&W2. Made an image on alcohol and mounted on Daemon Tools and it works fine. But when i uninstall it and reinstall using the mounted image it wont let me play. Whats the problem?
EDIT: I havnt tried playing from original (once installed from image). I burned the image on Alcohol with bad sectors emulation. What is cureROM? I havnt been on forums for a long while so i'm out of date.
