Fear 64 bit
  • Fear 64 bit
    Hi guys im trying to get an image or a no cd crack to work for fear v1.05 or 1.06 in 64bit Windows. Ive tried curerom but it dont seem to work properly as fear still quotes wrong or no cd inserted. Just looking for suggestions or maybe some has done it before. Its says "take out current disc/dvd and reinsert original in e:"
    Ps sorry if double post
    First question will be how did you make your image, and with what software?
    Coz F.E.A.R. runs damn well under x64.
    Carpe diem
      F.E.A.R. works fine under x64 on my system as well. Using the latest Alcohol (same virtual drives as latest DTools) and the 1.05 patch. You should probably try remaking your image, as it sounds like the image isn't correct. And please don't mention cracks.
