I can't play the game. I tried with the newest version of curerom(2.0.3.1) and it says that i don't have the DVD in the drive. Any sugestions?
Matrix: Path of Neo problem
AFAIK Path of Neo has Securom 7. So try to recreate your image (maybe you got a bad dpm, tough you had the best settings).
also check if you have any star-force drivers installed, because they don't let you make good dpm's. if necessary uninstall them.
try the newest asr (v 1.2) you can find it in the download section
