When I mount the file with DAEMON Tools, the game starts up. But then it says I need to insert the CD into the CD-ROM. It works if I insert the real CD into the real CD-ROM, but how can I fix/go around/re direct it so it uses the virtual CD in DAEMON Tools instead?
Ops, nevermind, my brother helped me, and it's working now.
I have the same problem as you do but it can't read the files then I found out that I should click read all files and then when i select the program to mount i go to my computer and double click on the drive and sais it cannot load and this is not a problem with the game.
