I mount the .mds or .mdf file with Daemon tools and i get to and complete the ODBC setup but then it just exits out and nothing happens...I've picked reinstall, remove, add/remove with the ODBC setup and nothing works, still exits out after it succesfuly did that part..
first state your system specs including your OS, sometimes i've had similiar problems when installing games (with XP 64 bit) that wasn't a daemon tools problem, it could also be your image, state what settings you used in alcohol
we used to eat food but millionaire scientists got together & wanted us to eat a bunch of chemicals
