Problem after mounting
  • Problem after mounting
    Hi. I have an .iso of frozen throne and when i mount it, my computer reads the mount.
    However, my problem is when I try to launch the game, it tells me to verify that Frozen Throne cd is in the cd-rom . Can anyone please try and help me out?
    Fozen Throne is protected by Securom 4.8.
    To get the image working you need an image which contains the DPM data. ISO images cant do that, you need to use another image file format like mds/mdf.
    Get ALcohol 120% and read a new image of your original cd.
    Choose the Securom4.x/5.x profile in alcohol .
    Try if its working with that image.
