new to daemon and alcohol
  • new to daemon and alcohol
    i just made an image with alcohol 120 v1.9.5.3823 and then i went to dt and i use mount image i did that and then it if i want to start it says insert correct dvd
    the game is the godfather and i am doing this because i cant get out of a car
    please explain everystep to fix this
    Hey, as far as your image problem is concerned, as the game uses safedisc 4.6 according to game data base, try using curerom(latest) or Prot.Stop. That might solve the problem. As for the glitch in the game; have you downloaded the latest patch?
      How did you create your image (program and settings)?
      The car issue is caused by using a crack, plz read the rules!
