Hi, I am trying tirelessly to get a legit backup of Dreamfall The Longest Journey to run. I used Alchol 120% v.1.9.5(Build 3105) to make a disk image of all 6(yes 6!) CDs and installed from the images with no problem, then went to mount the image in Alcohol 120%, but the copy protection(SecuROM 7) detects the emulator and thus does not run. I have tried the following:
What I want to know, is what is the proper settings to use when creating the images with Alcohol 120%(I used the default profile for "securom *new*"), and what software tools/settings do I need to run the images afterwords? Thanks for the help, and note that all my other image backups work flawlessly with just Alcohol 120%.
edit by Admin: Please don't post more than once. The forums are moderated which is why your posts don't show up immediately.
Sorry about that, just realized what that ment, never been on a forum where it is reviewed before, thanks!
- Use Daemon Tools (latest version) instead
- use regedit to mask the Scsi ports/drives by disableing permissions and by renaming the keys
- use CureRom
