Hi, I have burnt all 3 of my diablo 2 cd's and burnt the Expansion cd.
I have burnt all 4 cd's on alcohol 120% with DPM 1x.
Now I load Diablo 2 and install that fine. But after that is installed I go to install Lord of destruction and for some reason it will not accept the play disk image. Nothing seems to work, even if I place the original cd in the drive it still doesn't work. Anyone know how to fix this?
