Hello My Name Is Ariel and i'm from Argentina.
I got a problem with the game call of juarez,
i made and image file then i mount it with Daemon, i install the game everything ok but the problem comes when i want to run the game it check for the original DVD and then it says the next: "It has been impossible to authenticate the disk in the established time check http://www.securom.com/message.asp?m=timeout&l=sp for more details" or something like that. What is the problem and can you help me?
thanks for your time
