Problem - Insert disc into another drive - LA RUSH
  • Problem - Insert disc into another drive - LA RUSH
    What tha hell this means ?
    Im using a image that i created with alcohol 120.
    And im receiving this message when the protection trys to read the cd, im using dt4 and sfn disable node and disable cd.
    When i try to disable Ata, the pc restarts with a error message.
    Tks for any help.
    Just unplug your cd/dvd drives physically.
      this is the only way ?
        Yes, Daemon Tools Pro will have v-ide (virtual ide) drives so you havent to unplug your real drives but it isnt released yet.
          excelent, tks for the info, but do u guys know when this version gonna be released?
            The search function would have told you when Daemon Tools' gonna be released. When it's done.
              If anybody manage to activate Spell Force 2 with patch v1.2 and how. Does mini-image exist for this version? Please HELP?
