Mechwarrior 4:Vengeance
  • Mechwarrior 4:Vengeance
    I'm using Alcohol 120% to make an image but I can't get it to dump. It gets to like sector 800 and errors and then continously does again and again. I've tried Laserlok, securom, safedisc 1 & 2 and a couple of the others. Got any advice?
    Use SafeDisc2 profile, the errors are part of the protection, so donґt care about them. If your writer canґt write the so-called weak sectors correctly youґve to use SafeDisc emulation.
