After various posts about using the CD/DVD-ROM's "Autorun Menu" to get around the SecuROM 7.x protection (detection of DAEMON Tools), I decided to do some digging around...
*NOTE: This will NOT work for all SecuROM 7 Games, Mainly UbiSoft games, but there is no harm in attempting this with other games too...
*NOTE: This will also ONLY work with DAEMON Tools 4.0.6
Ok, so here is how it works...
You know that the Autorun (i.e. UbiAutorun.exe) is run from your CD/DVD-ROM lets say E:\
The game (i.e. GRAW) is run from "C:\Games\GRAW\GRAW.exe"
Well what the Autorun does is, it runs "C:\Games\GRAW\GRAW.exe" but from the location of your CD/DVD-ROM Device...
Q. So, is there a quick way around this " Loop-Hole"?
A. YES...
Oh ok, I suppose you want to know how...
Just edit the games' original shortcut (right-click on the shortcut, select "Properties")
Now, you only need to change one thing here...
Change "Start In:" to the path of your CD-DVD-ROM (i.e. "E:\")...
Click '"Apply" then "Save"... and you are done...
*NOTE: the "Start In:" location does not have to be the CD/DVD-ROM with the your games' image mounted... it can be ANY CD/DVD-ROM Device, as long as the Disc's "Volume Name" is valid/exists...
I tell you this because some mini-images do NOT have a valid "Volume Name"/"Disc Name", so just make sure "Start In:" points to a CD/DVD-ROM with a real/valid "Disc Name"... else it will give you an error...
The above method should work with... "GRAW", "COJ", "SSam 2"... and others I suspect...
So use this info while you can, cause i'm sure that it will be rectified soon...
Edit:
@Moderator: sorry was in a mad rush when I posted, this should be moved to "Copy Protections", my bad...
A. YES...
Edit:
