hello, I am having problems installing MOHAA (Medal of Honor) that consists of two ISO files. I mounted both files on a virtual drive and In the middle of the install, Windows will ask me to select the correct disk, At that point I will mount disk 2 to the same drive disk 1 was in and hit ok on the windows "select correct disk" window, and then this Component transfer error window pops up:
component: sound dialogue files
file group:
file:
Error: catastrophic failure
What do I do to fix this? thanks
file group:
file:
