toca3 and dt 4.06
  • toca3 and dt 4.06
    Hi, I have DT 4.06 installed , and when i play toca3 it starts fine, but just before a race starts , i get a CTD. what could be causing this? v 4.06?.
    What happens if you play from your original CD/DVD?
      try to update youre drivers and what are youre system specs??
        hmmm it cant be v4.06 because i get the same deal with the original disc. but it used to work fine. maybe its the 91.47 driver.
          you should try another driver then.....there are some problems with race driver.....
          do you have a dual core processor?? then deselect one core...
          do you use the latest version of Race driver??
          also take a look on their forums...!
