I installed daemon tools and mounted a image file.Where is the virtual drive to play the image.I looked in my computer,but it only lists my dvd/cd burner.
Help with virtual drive
Is autoplay active on your windows? Rightclick on Tray Icon/top point/
and then you see "Device 0: [ X:]" - x is the virtual drive letter.
Now in adress bar in explorer you type X:\ and then you can see your virtual drive.Make something idiot proof, but then they just make a better idiot
