i took and copied the files from warcraft3 off the cd and onto my hdd and then burned them to disk. i didnt use a raw copy or image or mds or anything. i can install the game from this backup but cannot play it. i tried to use the backup, with alcohol120%, and make an image file, and then use that with daemon emulation running and that doesnt work either. is there any way that this copy i made will work? when i scan it with clonyxl it still detects the securom 4.6x protection. its not the 4.8x so it should work without the physical emulation right? im not sure, can anyone help me?
i think i copied it wrong but can it still work??
