Ok....i've successfully made an image using alcohol 120%, and i have a laptop that i want to put this image on it tells me i can't due to copyright...this is the reason i got daemon-tools was to put games onto my laptop because the CD drive doesn't work....so i created an image on another computer.... the game is Red Alert 2....can someone help me....
1. How did you create your image (which settings did you use)?
2. Which is the exact error message when you mount the image and want to play the game (if you dont know how to mount an image see the Daemon-Tools Help) ?
