SI Sega Football Manger 2007
  • SI Sega Football Manger 2007
    Hello everybody,
    has anybody already tried to copy this game?
    I can't understand which protection the game has!!!
    Pls let me know if i'm wrong anywhere.
    Thanks
    How would we know? You said nothing about how you created the image or copy you're talking about. If you don't tell us what you did, how are we supposed to know what you did wrong?!
    Which software (-version, -settings) and what hardware did you use to create the image? Use ProtectionID (-> google) to find out which copy protection's used on that game.
      The game uses Safedisc 4.6, you should be able to create a working image with Alcohol 52% or 120%, using Safedisc 2.*/3.* profile.
      Don't worry about all the read errors, they are part of the protection.
