making mini images
Use a software called alcohol 120% which can be downloaded at www.download.com.
then insert the cd/dvd u want to create the mini image.
start alcohol 120% n click on 'image making wizard' option.
then chose safedisc from the left down corner dropdown box.
change the read speed to 1x(150kb/sec).
then follow the instructions!!!!!!
but when the image is being created stop the process at 5% n click on yes option.then say no 2 delete the files.
then ur images .mds n mdf will be created.
mount them in daemon tools n then use the safedisc 4.7 to create a backup registry n start the game!!!!!!!!!!!
i have the .pdf manual.give ur email address if u want the file.
 ... and to start the log in the right moment
 , don't know whether they're all part of the check, so no guarantee for this Blindwrite 5/6 profile (save as BF2142.ini and copy to C:\Program files\VSO\BlindWrite5(6)\profiles):
