need some help.....? pls??
  • need some help.....? pls??
    ok
    i want to play a game whitout using the cd.
    how do i do that??
    i got the orignal CD
    i tryd making an image of it and mount it into on of the drives but it dint work.
    can some on pls help me.
    Would be a good start to post in the correct forum, and to mention the game, so we know the protection.
      its StarWars Empire at War
        Which software did you use to make an image?
        Which format is the image in (bin+cue/iso/mds+mdf)?
        Which settings did you use to make the image?
          i used Alcohol 120 %
          its an mdf format
            And which setting did you use in Alcohol 120%?
              i used image making wizard
              skip reading erros
              read sub-channel data from current disk
              data position measurment (precision: normal)
              read speed maximum
              datatype customize
                For CDs, you need to select a slow DPM measuring speed.
                  And you need dpm precision high.
                    it sais it cannot get the right DMP info from the disk whit current device
                    • #11
                      And DPM extraction worked for you with high speed?
                      What's your dvd/cd-rw drive, check its compatibilty with the list of drives at Alcohol's Page:
                      Alcohol is CD / DVD burning copying backup recording duplication emulation and creation software.
                      • #12
                        DPM errors
                        I'm having the same issues apparently. Here is what I have:
                        ASUS -> CRW-5224A
                        Manufacturer ASUS
                        Model CRW-5224A
                        Supported Writing Method: [TAO] [DAO/SAO] [RAW SAO] [RAW SAO+SUB] [RAW DAO + 96]
                        BURN-Free supported: [FlextraLink]
                        Best Writing Speed:
                        Supported Media: [CD-R] [CD-RW]
                        The disc I'm trying to copy is: Super GAMEHOUSE CD and I can't find any information on what type of protection they use.
                        I used Alcohol 120% Copy Wizard
                        Skip Reading Errors
                        Read Sub-channel data from current disk
                        Data Position Measurment (precision: High)
                        Read speed 1x
                        Datatype SecuROM
                        It says it cannot get the right DMP info from the disk with current device.
                        Any suggestions?
