rise of nation -keeps asking for cd!!!!!
  • rise of nation -keeps asking for cd!!!!!
    with patch 1.02 it keeps on asking for cd. I use daemon 3.33 and use alcohol to create clonecd format of the cd to use as image. It still does not work. What did i do wrong?
    It worked before the patch :?:
    Hell Hath No Fury Like ASPI Abused
      I went into similar problem with Civilization III. Try to change the drive letter parameter to the drive you originaly used to install the game.
      It might not be it but it is worth a try.
      Don\'t waste your time always searching for those Wasted Years
