I just bought BW2, how do I make a backup cd(So I wont need to use the original) I know you need to copy it with a program, but I doubt it isn't copy protected.
Ok, I just bought BW2, how do I make a backup
Yes, it works with other games as well. You will need ProtectionID to find out which copy protection is used on a certain game."I was inappropriately blunt, wasn't I? Sorry, I do that a lot."
Long since I have been on (Does that work with other games too?(I suppose it does... or?....))
