Prince of Persia 2 thrones install problem
  • Prince of Persia 2 thrones install problem
    I mount it with Daemon tools then click it the first screen comes up I click Install Prince of Persia then the command prompt screen comes up for a second then dissapears and the computer acts like nothing happened. Any suggestions?
    How did you create the image, which program and settings and work the game with the original cd's?
    What version of DT do you use ?
      Does this error also occurs with your original disc?
