Civilization III CD Check
  • Civilization III CD Check
    Hi everyone,
    I recently did an iso file of the game (v1.29f) and tried to mount it on D-Tools. Even if I used the proper security options and tool to create this ISO (Alcohol) it failed.
    After a few tests I realized that some weird security check is made to validate if the CD is in the drive you originaly installed the game from.
    So by changing the associated letter on the mounted virtual drive accordingly, I managed to make the game work.
    It's the first time I hit this type of security check. However, I must admit I haven't used mounted images for gaming purposes very often. Is it a common practice?
    Don\'t waste your time always searching for those Wasted Years
    In old versions of games (usually ones with safedisc) this was quite common.
      this is the error i keep getting - how would you suggest i fix this?
        search in the registry in "HKLM\Software" for the game and check if there is any drive letter saved in there.
