Okay, I have a game with all the expansions that I want to install. the base and expansions 1, 2, and 3 have installed properly with Virtual Daemon Tools Manager, but when I go to install expansions 4-7 it installs properly, but afterwards a window pops up that says "Please insure disc is in the drive, select OK and restart the application". I got another version of this game and that still didn't work. Then I got Alcohol 120% and the same thing happened with both versions of the game. Is this a problem with the emulator program, because it happened with two different versions of the same game. How can I fix this?
Won't recognize Discs
How did you create your images? Which programs and settings used? Which version of DT are you using? Which game do you want to install?
Scan your CDs/DVDs and the installation folder with ProtectionID ( google ) to find out which copy protection is used, then recreate your images with Alcohol using the appropriate profile.
