When I try to start FEAR: Extraction point I get the following message:
Warning! Your system time appears to be incorrect, would you like to verify it against the SecuROM Timeserver?
I can select yes and no, but I don't dare to select yes.
When I do select no, I got the following message:
Invalid system-time detected.
Please check and correct your local system-time setting.
What's wrong?
What's wrong?
