i want to create a backup for halo but i cant get it to work. i used alcohol to make mds/mdf and used safedisc 2/3/4 but when i mount it, it says to insert the correct cd.
okay i got it to work, but after playing for a while, it alt tabs out and says "gathering exception data". when i restart halo and get to the same spot, it says it again. does anyone know why this keeps happeneing?
