Help with Splinter cell Double Agent with 1.02 patch.
Using a mini image in SCDA patch 1.01, YASU 1.2b was able to make both SP & MP work.
Yet this 1.02 patch i can't get multiplayer to work, only Single player.
i am using YASU 1.3, with daemon tools 4.08 (including SPTD 1.38)
any ideas?
when running multiplayer, securom will return a result of:
yet only have 1 drive, all the rest are virtual. and if i disable the drive the game just crashes into windows report tool.
any ideas?
Please remove disc from current CD/DVD drive and insert the original "Splinter Cell DA Master" disc
in drive J:.
Please have a look at http://www.securom.com/message.asp?m=other for further, more detailed information.
in drive J:.
