Well, many ones claims about a successful DPM injections...
Well, it's not my case
hehehe
I tried to make an image of my Knights of Honor disk, but I had a problem about the DPM extraction, I guess it's not supported by my burner...
So I decided to use this little thing but, I failed...or the program failed to inject the BWA correctly...or Daemon failed to mount!
hehehe
Anyone have a give to inject a BWA into a MDS ?? The copybase.ch tutorial is no more...
Now I will describe my problem:
I downloaded an BWA of Knights of Honor....then I made my image of the disk 2, without DPM extraction...
Then I run Quickmount,go to DPM injection (guessing), and then selected the BWA, then the disk 2 MDS, and the program said:
"DPM info available, continue?" or something like that...I choose YES.
Then I tried to mount it with Daemon and it says Invalid image file!!!!
Anyone knows about this problem!?!!?!?!
Help me, please.
Thanks in advance.
heheheI tried to make an image of my Knights of Honor disk, but I had a problem about the DPM extraction, I guess it's not supported by my burner...
hehehe Anyone have a give to inject a BWA into a MDS ?? The copybase.ch tutorial is no more...
Help me, please.
Thanks in advance.
