Yeah, i've got a little problem. I had alcohol 120 with a virtual drive, uninstalled it, but for some odd reason the virtual drive is still there, even after uninstalling; it pops up after each time i restart my computer. anyways, i need help to try to find a way to uninstall it permanantly, as some games such as EAW with securom7 says that i have a virtual drive running, even after the uninstall, with the real cd. someone help me try to remove it?
Daemon Tools 4 running when it isn't?
1. Never beleive what copy protection says. You DON'T need to uninstall DT4 or Alcohol to play.
2. Use Yasu to hide your virtual drives
3. Did you try to manually uninstall the drives? (googling might help, and procedure is on this site)
4. Duplex secure provides a standalone executable for their drivers, can be used both to install and uninstall.
Hope that helps.Carpe diem
