I want to play Starcraft without the CD. I have downloaded Daemon Tools and i was told that it could somehow do something to let me play without the CD.
I'm just wondering what I have to do?
Anybody know a step to step guide or something? I am new to all of this so bear with me.
I did make a mini-image (.iso format) for Starcraft which also works for Broodwar.
I had to use an .mpq editor (edited install.exe) to make the mini-image work for both.
EDIT:
The disc does have some security on it but the .iso holds enough info, just be carefull not to "damage" the image file if you are goung to editing it.
Neither Starcraft nor the Broodwar extension is copy protected. You can make the image with almost any app capable of making a disc image and then mount that image on DT.
Copy the data files from the starcraft cd onto hdd. Go to registry and point at the directory containing the starcraft data files you have just copied. It should be able to work.
