please insert cd
  • please insert cd
    I would like the daemon tool for the game "FIFA 07" (picture created with nero).
    I use the daemon script the execute the script.
    I have the message : "please insert cd"
    what the problem ?
    thank you for your help
    Regards
    Don't create image with nero, you should always use Alcohol 52/120% to make image.
    Also use YASU to avoid blacklisting.
      Before creating the Image with Alcohol you should indentify the copy protection.
        Safedisk 4.6
          hello,
          how to you use YASU ?
          Just execute the program ?
          Regards
            1. Create Image with Alcohol
            2. Mount Image with Alc or DT
            3. Run Y.A.S.U
            4. Run the game
