This is a pretty weird one. One windows XP and XPx64 when using an ISO image of some REALLY old games (like Lands of Lore 3 from 1999) the setup FAILS to run from the image, saying "insert CD". But when you burn that same image to a CD and try to run it from there, the setup run's successfully.
I am not quite sure if this is a bug in DT, a bug in the setup utility , or a copy protection issue. I think its NOT a copy protection issue since that game probably does not even have copy protection, as its not listed to have one anywhere where I read, plus it works from a disk that was burned in nero from an ISO.
